Front driveshaft U-joint replacement….
Alabama
Have y’all used this one and , if so, how do you like it?
TIA
Matsuba or OEM
if nothing else, the seals are far superior.
The seal set up on these means you can pump in fresh grease until old grease is flushed out of all four corners with confidence that you've got fresh grease through the whole joint without blowing out one of the crappy aftermarket seals first
Another vote for Toyota or Matsuba
Example: still running the original rear U-joints in my 96 model with 380,000 miles on the clock. Keep them well greased, IME at least every 10,000 miles when new, more often (7000-5000-3000 miles) as they get miles/age on them (and immediately if they've been underwater) as the seals don't hold the grease as well as they did when new. FWIW
