er cant finish rebuild need damn grease seals unless there is way to remove w/oharming them
Which seals are you talking about? The ones on the back of the knuckle, sometimes called wiper seals?
-B-
on thing that did spring to mind was how many preload shims should be there from new? mine had one,
And how did it work out?
By the way, it seems to be spending money on a seal tool is a waste of money. Get a piece of wood that is long enough to extend out of the housing and pound the sucker in that way.
-o-
I'm about to search this thread for more info, but if it isn't already covered: do you have a part # for those bearings? are they in addition to the regular bushing? Or do you need a different bushing? if I can source a timken bearing (or Koyo) I'll probably add it to the mix when I re-rebuild next week.
man I wish you had posted up re: the roller bearings for the spindle about a week ago... I would have gotten some for the re-rebuild I'm doing on the driver's side.
The newer style roller bearings in the spindle are only available with the purchase of a new $pindle last I heard.
That used to be the case 2 years ago.
Now, thanks to Dan, those roller bearings are now sourceable for stock spindles that do not have the roller bearings and only have the bronze bushings and sleeve going down (these were the stock ones that we received as OEM from Toyota when these rigs came into the country).
Give Dan a call and he can order these for you and you can re-use your old spindles.
-o-
