Chicago what about a UN-limited slip in the front?
Fixed it for ya.
I didnt realize that longs have free shipping to boot! Not too bad!
So would I need the 30 or 27 spline?
I dont recall the spline count on these rigs...does it matter?
Chicago
How about this:
Locker up front, run one front wheel engaged, the other free (3 wheel drive), then when really necessary, engage the other front wheel.
Now, will 1/2 of the front system handle the torque? I believe the locking hubs and shaft will have to be beefed.
An interesting idea, no?
One of the guyz in the club is wheeling a 40 with NO POWER STEERING, stock axels and a lock rite up front...
He weight about 100lbs to boot.
HARD FU*CKING CORE!
Chicago
Chicago
bad idea
My $.005 is I would steer away from the auto lockers, some people have good luck with them but alot don't(myself included).
In my FJ40(SBC,SM465,36"s) I ended up pulling both lock-rights out, welding the rear and leaving the front open. much better combo for that rig.
In my FJ60 I dropped some coin for an ARB and Marlin's 27spline UM06's. I've still got stock inners and I'm pretty sure I won't have a problem. The thing I love about the ARB is I only use it when I need it(=to lazy to back up and try a different line). The 60 has a lot less motor so i kinda need the locker and when in the 40 I can just power my way out of it.
also you dont need the ARB compressor you just need some type of air supply(co2,cheap costco pump, etc...) and you can get a manual switch for the arb from a couple of different places, i.e. ARB Air Switch someone on mud was making thier own and selling them awhile back
ARB $700
Marlins UM06's 320
or Bobby's 27's 430
compressor 50-100
manual switch 37
or
lockright 300
Bobbys 30's 665
hydro 300
hydro can be done slowly.
The $300 would be for the ram and a ported box. You can always do your own..
The ram is ~ $100
If you are gonna pony up for bobby's alloy inners then just go 30 spline.. If not, get the $430 stock replacement birfs and use your stock inners (you will probably not break them)
Crack is for weenies![]()
The ram is ~ $100
Nope....slap them puppy's inSort of a hyjack but in fitting the 30 spline inner axel longs does the carrier in the differential need to be changed or is it still stock dimensions. Thanks
so what's wrong with a LSD in the front?
Quote from freds40's thread on Marlin's board.
"I did all my shopping @ surpluscenter.com. They had everything on the shelfand I got it in a matter of days. The ram I got is a Columbus 1.5x6x.75 Dual action cylinder(Dual action reffers to being aple to preassurize in either direction rather than just bleeding off) and was $78.50.PN 9-4410-06. I used 2 premade 1/4 x 36" single wire hydraulic lines that were $7.35 each. PN 916-1436. 2- 3/8 NPT to 1/4 NPT bushings because the ram has 3/8 ports and that is too much volume and would make this system too sluggish so you choke it down to 1/4 ASAP. These were $.45 each. PN 9-1938. And I used 4- 1/4" male/female 90 degree fitings. PN 9-1922. These were $1.95 each. You have to make sure to ask for hydraulic fittings otherwise you might get hose regular hose fittings and they won't seat and seal properly."
Hydro assist on the cheap
I'm sure prices have changes a little but they're close.
That's RADDDDDD!
Ill be investigating that.
I like the stuff I can do myself.
Chicago
