Front AC cold, rear AC warm,?
PG, UT
I've just replaced front evaporator and expansion valve, vacuumed, and charged. Front AC blowing cold.
When I turn on rear AC, it blows warm. I quickly turn it off in case there's a leak and I'll lose my refrigerant and then front AC will stop working, too. So long as rear AC stays off the front continues to blow cold. Is this a common issue? What's the likely culprit?
2005
Thanks!
My guess would be a failed expansion valve on the rear evaporator.I don't think there's actually any isolation valve for the rear AC, but I could be wrong.
There is a single compressor for both systems, so the high and low sides are connected throughout. I suspect @Eyedaho is right or that some other rear A/C component is bad.
