Pura Vida
What an absolute noob
Also, the Toyota hybrids dont require any special maintenance. Just standard oil changes, tire rotations, etc.
They probably have less brake maintenance due to regen.Also, the Toyota hybrids dont require any special maintenance. Just standard oil changes, tire rotations, etc.
Just to be clear this is when the warranty ends not the life of the battery. You won’t need to replace your battery every 150,000 miles.
I mean, whether it's a birfield rebuild/HG, Timing Belt, or Hybrid battery, every LC has had to have a big service at certain mileage intervals. If you think of it that way it makes sense.
Not sure I agree.....it's under a cover in the rear of the rig. Un-cover, un-bolt, un-plug, replace, then reverse of removal. No gaskets, need to align timing marks, pull radiator, flush cooling system, etc. I'm wondering if you even need a torque wrench, and guessing your hands would even stay clean. Maybe just a timing belt is a <1 day on a 2UZ but it will take longer if you do other preventative maintenance at the same time (I've done one before).I'd argue the timing belt is pretty minor maintenance though. It's a few hundred bucks and less than a day of labor if you tackle it in your garage. A hybrid battery replacement seems pretty major compared to that.
I’ve seen prius cars drive into the service center with over 300k with no issues. Battery technology has advanced a lot since they were made too, so I would guess over 300k easy.I guess I'm cynically assuming the average battery will need replacing soon after 150,000 miles. Any idea how long these last out in the wild?
Companies do Prius replacement batteries with free onsite installation. Like mobile windshield replacement. Not sure I'd want to tackle a timing belt on the street but apparently it can to done with a battery. A used battery also has residual value and can be recycled/remanufactured.
Having done my wife's 100 series 3 times now, it's a good day's work and more than a few hundred bucks if you replace the water pump, tensioners, belt, and bearing/roller assemblies as PM. Not something I look forward to, but not rocket science either. Right up there in the "damn, this is a PITA" category is a starter replacement on a 100.
I would only buy a Aisin kit from Amazon if you are feeling lucky. Add in a bottle of coolant and other consumables like spark plugs, new drive belts, a couple of coolant hoses, and other stuff that will pop up and it will be closer to $400-500 in parts total. Not bad overall.
I do think that hybrid vehicles have a much lower lifecycle maintenance cost than a straight ICE vehicle. The big question mark with Toyotas new truck/SUV hybrids are the turbocharger. If they end up needing a new battery AND a turbo or two and other stuff like a wastegate in that 150-200K mark, I think they could have higher lifecycle maintenance costs than either a non-turbo hybrid or a non-turbo ICE engine. Ask anyone that owns a Ecoboost or turbo Subaru - turbos don't usually make it past 175K.
You should consider yourself very lucky, others have gotten kits that did not appear to be Aisin and may have been knockoffs. The best place to get Aisin/Denso stuff for cheap (where the supply chain is legit) is Rock Auto. It's not worth risking your motor, I don't buy any engine parts off of eBay/Amazon any more. Just cheap Chinese stuff I know is cheap Chinese stuff and am OK with.I guess I got lucky, my kit has almost 100k on it.
forum.ih8mud.com
Toyota claims that they are testing their turbos for a commercial lifecycle and that they should last the lifetime of the vehicle:I would only buy a Aisin kit from Amazon if you are feeling lucky. Add in a bottle of coolant and other consumables like spark plugs, new drive belts, a couple of coolant hoses, and other stuff that will pop up and it will be closer to $400-500 in parts total. Not bad overall.
If anyone can do it, it is ToyotaToyota claims that they are testing their turbos for a commercial lifecycle and that they should last the lifetime of the vehicle:
Whether that is true or not, only time will tell. The fact that the turbos on the V6 are such that they had to remove the Tundra bodies to replace them when they had teething problems is certainly suboptimal. That shouldn't be as much of a problem with the 4-cylinder turbo as the engine isn't as wide as the V6. Toyota's focus on cooling of the turbos is, I think, the correct approach. As long as they can keep the turbos cool, I think they can last a long time.
