Good morning,
Not to jump in and HiJack the thread, this is Sonny form Downsouth Motorsports and we just became and vendor on here (No I am not going to try and sell you something right now) ha,ha...
But some of the valving combos are interesting to read and some of the questions because I am normally the one who works on the shocks and plays with the valving. One thing I would like to note is that just as it was stated earlier that we will re-valve the shock as many times as you would like us to (Customer pays the shipping to us and back to them) until you feel comfortable.
Valving is subjective and that is what happened early on and we were hearing so many different responses from different valvings we were sending out.Light compression and slow rebound and then they needed more compression and faster rebound and so on and so on.
Then you throw in the added weight and different spring rates and compression adjusters and then we had trouble getting accurate info from some of the customers and that threw a wrench in the whole program.
Fox pistons are cast in there standard off the shelf 2.0" shocks and they normally have a "2" Bleed hole piston in them. Some of the stem top stuff comes with "1" bleed hole in the piston depending on who you order the shocks from. The stem top 10" shocks are normally a universal stem top shock and that is why there is an inconstancy in the piston.
Valving is infinite and we are here to help you with any questions you may have whether you choose to purchase shocks from us or not.
Now just a side note on valving:
2 bleed versus 1 bleed:
1 Bleed open will increase the low speed for tighter feel so to say mainly because you are forcing the fluid to travel through the valve stack instead of allowing it to free bleed under a hard hit.
Here is a valving I would like to try for the front mainly:
Compression:
1.60" x .008
1.425" x .008
.950 x .010
1.425" x .012
1.350" x .012
1.10" x .015
1.10" x .010
.950" x .015
.800" x .020
Rebound:
#80
Single Bleed hole open piston
DU style wear band for the piston
Non compression adjuster
Standard weight vehicle (No extra weight)
Daily street driven rig.
Let me know if anyone ( one or two people) are interested and I will send you the
valve stacks at no charge and cover the shipping in the USA.
If you message me it will go to Micah's e-mail...so you may not get a response for a day or so, but I will do my best to keep an eye on the thread if anyone responds.
Thank you,
Sonny
Good morning,
Compression:
1.60" x .008
1.425" x .008
.950 x .010
1.425" x .012
1.350" x .012
1.10" x .015
1.10" x .010
.950" x .015
.800" x .020
Rebound:
#80
Thank you,
Sonny
Waiting for parts to show up. USPS international plus the border nazis and it will prolly take a whole month lol.
I recently did a trip out to Death Valley and traveled some rough roads. The shock (2.0 remote) body's got
f-ing hot. I burned my finger touching them then pulled my arm out fast enough I banged my elbow on the flair and cut it.
Well anyways, do I need to change the oil out or anything like that? I have the nitrogen and the no loss valve already.
.008 ----------1.600---------
.008 ---------1.425--------
.020 ---0.800---
.010 ------- 1.350------
.015 ------1.100-----
.015 ---0.950---
Great info! I'm using the same coils at roughly the same weight. I don't fully understand the reasons , but the biggest improvement I've experienced came from switching to 255's last week. Steering, cornering/body roll, harshness on washboard (at 35 psi!). This was from 285 load E Duratracs to 255 load E Toyo MT's on 6.5" wheels. I'll probably stay with original valving.
Alot can be said for tires. What psi are you running offroad?
With corrugated roads (we have a LOT of those in oz), air DOWN! Let the tyres do some of the work!
cheers,
george.
