Any word on if these will work with an OME J lift?
I believe rwhats is using j springs. You'd gain some up travel at the expense of down travel on Js. And bumpstopping would be required only for tire rub issues and not shock travel issues.
OK - finally had time to get the rears installed.
I one up'ed you Brian - I only swapped out one OME and went for a tour. Got a late start and wasn't going to get them both on that night. There was 6" of pow outside when I opened the garage door, so took her for a rip. No comparison when turning (fishtailing) or braking. Solid. OME = scary.
I think the rear valving will suit the 863's when loaded (need to finish getting that aux tank installed). It's crisp when unloaded - so anyone with less weight - be sure to ask Neil at DSMS about lower valving (IMHO).
I've had 4000 km's worth of roadtrip's on the front now. I was concerned about stories of other shock brands seals leaking in winter temps. I gave them a 5 hr beating in -25 with no problems.
I'll mention the resi fit on the rear is really close to the caliper and sway bar. Clearances with the small 285's seem to be no problem, yet. 315's, plan on fabbing some brackets..... Good thing they're only 2.0's!
I'll probably look into flutter stacks for the front - down the road. I think this may be the way to go for all-round valving. Maybe Coax will chime in.....
The biggest PITA is really the mounting/mounting from the vehicle. They are a SOB to put on/take off.
If you have access to nitrogen to charge the shocks it's not bad.
I did my rears on the ground without jacking up the truck. Undo bolts. Discharge nitrogen. Collapse damper and remove.
The rear lower bushes are a bit of a pain tho. Pry bar to remove, and longer bolt to install, followed by the proper bolt once the shock is half on the bushing. If installing a charged shock, you can quickly jack up one side of the frame to make it line up.
I charged mine after installation. I also have a 6" height extension for my floor jack.
A man after my own heart. So anecdotal reports (bikeman, coax, kmcoop7, thomo) seem to favor compression in the 35-45 range (with flutter stacks in some cases) for light to medium loaded rigs. Heavy rigs seem to like something around 65. Rebound from 75-90 has appeared satisfactory for rigs of all weights.My flutter stacks are working better than the previous standard valving I had, but I still think it could work better. Ideally I'd like a larger range, where its less compression on the small bumps (thinner large diameter shims) and more compression on the bigger bumps (thicker smaller diameter shims) but not sure what the "spread/range" can be on flutter stacks. Maybe even just using 1 flutter shim instead of the two that are on there.
My only thought on softening up slow speed more would be moving the flutter spacer from the 3rd position to the 2nd. You mention having two "flutter shims" but I think you only have one. Maybe we are both trying to say the same thing different ways here as far as moving it?
So moving from this (your current front AFAIK):
1.6x.008
1.425x.008
.8x.01
1.35x.01
1.1x.01
.95x.01
.8x.02
To something like this:
1.6x.008
.8x.01
1.425x.008
1.35x.01
1.1x.012
.95x.012
.8x.02
Just an idea! I will likely be trying something in this range on my own truck soon. Keep the info coming!![]()
If anyone is in the socal area we may be able to hook up and DYNO your set up.
It is great to be able to quantify what kind of change you are making.
Are you guys messing with the free bleed on the piston. This is going to influence your very low speed a lot, possibly allowing you to get the shims more effective for high speed
Thats awsome. Shock dyno or suspension dyno?
It seems all are running only a single bleed. Going by their numbers. Im going to try something new with this new set of fox Ive ordered for a customer.
Shock dyno.
http://www.youtube.com/watch?v=g-FqR7AS3yg
I can run a shock way harder than it will see in the field. I could burn the stickers of a shock in a couple minutes
I don't think the bleed holes on a fox are threaded. Drilling a tapping a couple holes for small set srews makes for easier tuning. All our pistons have between 3 and 5 #3-48 holes tapped. Our tune charts indicate how many are open or closed.
Welcome to Mud, Sonny. :flipoff 2:
To further hijack.
Hated to hear Marco left. Great guy, one of the few that talked me out of purchases on the FJC (though still took a lot of money).
Can't speak highly enough about DSMs customer service.
We are still good friends and always will be..
Keep us posted if you need anything..
Always around like a doughnut to help...
