For Sale / Wanted Thread (3 Viewers)
I have some free 80 series springs.
4'' OME Rears - 863X
4" Slee Fronts.
Well used, no idea how old they are. Free to a good home. Text me at 405.343.6706.
Looking for wheels and tires for a trailer project.
Wheels - 15x8 6 on 5.5 need 2
Tires - 33 x 10.5 x 15, don't need to be new, just decent, Need two, wouldn't mind 3, I'd buy 4 if its a good deal
Free!
Front brake calipers and hoses for a 2008-15 200 series Land Cruiser or LX570. I also have low mileage front rotors (not pictured).
All components removed to upgrade, but they were working well before removal. Rotors are smooth without warpage or vibration.
I hate to throw out perfectly good parts, and I figure someone could use these.
PM if interested.
  • Like
Reactions: SAS
I’ve got a set of OME 895 springs that are like new. These fit 03-09 4Runner rear and should also fit Lexus gx470, tundra, newer 4R and other applications (check ome or arb for fitment). Retail is over $200. Looking for $140 pick up in the springs.
Anyone have a spare 80 series 1fzfe fuel injector they'd like to sell or I could use to send out to get cleaned with my spare set(set of 5, not sure where my 6th injector ended up)? I could return you one of mine when they are pulled and I put the rebuilt set in.
Thanks,
Pete
Thanks,
Pete
Have you already sent off your set of 5?
I have 6 waiting to get sent for rebuild. Just been lazy...
Dakota Digital SGI-8E Universal Tachometer Interface
I used this to get my LS engine to talk to my Toyota tachometer. Worked great, but just replaced it with the SGI-100BT for the additional speedometer functions. Looks like it's discontinued at Dakota Digital, but manual is still available.
I bought it in November 2019 for $85+shipping. Asking $40
Headlights!
1. Two Sylvania sealed beam 7inch Headlights. 20+ years old but they still work. FREE.
2. Two Koito H4 conversion headlights. Replaces 7 inch sealed beams. Essentially new, installed briefly but not used. H4 bulbs not included, but you'd probably want to use LEDs anyway. $30
I still have the good used 200 Series front brake parts for free.
Getting rid of some 4 inch tappared coils off my 80. The Front Coils are C59-614V and Rear Coils are C59-615V. Right now they retail for $365 per side on Dobinsons website and they are currently back ordered. $500 delivered to your door.
Really would like to get these out of the garage! $400 to your door. Here are some pictures of them as well and picture of how they sat on my cruiser.
Looking to clear some clutter out the garage that I have somehow accumulated.
From top to bottom in the main picture
80 series front left corner light - good shape
80 series front turn signals - lens in okay shape
60 series tachometer - worked when I pulled it a few years ago
Orion 1 inch wheel spacers - ran these for quite a while, worked great, comes with lug nuts
OME rear 30mm trim packer - new
Early FJ40 Land Cruiser emblems - Good shape, made of metal not plastic
80 series weather tech floormats for first and second row - tan color, good shape, they need a good cleaning
80 series OEM rear mud flaps - good shape, do not have original mounting bolts
80 Series OEM rear lower control arms - good shape, need new bushings
Wits End Birf to Hub Spacer - have no idea how I ended up with 4 of these, never used
Solar Panel Charge Controller - brand new
OTRAMM Front Crank bolt holder - Worked great for me when I replaced front oil seal
80 series blue hub fan clutch - Basically brand new, purchased and then could not use when I supercharged my truck. This might be the one from Wit’s End back when he was selling these with the heavier fluid but I can not remember
Kicker CXA300.1 Amp - Worked well for me, went to a bigger one when for a bigger sub
1000w inverter - never used
300w inverter - never used
Baja Designs light pods - never used
80 series throttle cable - in solid shape, came off my truck when I replaced with a new one when the supercharger went on
80 series Dobinson 4 inch Flexi Coils - probably have seen my other post, still need to get these gone C58-615V rear, C59-614V front
All of this stuff is OBO just need it out of the garage. Only exception to this is I would be willing to trade some stuff for a 80 series lower valance in good shape and a rear driver flare. Located in Monument but can deliver if necessary.
Cheers!
Hey Andrew, I could probably use that crank tool since I need to fix my front oil seal leak as well.
Pete
Hey Pete, I posted this thread on Rising Sun at the same time and literally 5 minutes after I posted it a guy messaged me getting dibs on the front crank tool. If you are going to do it soon though before the weekend, I could lend it to you. Sorry!
The only other thing sold right now is the BD lights.
Thanks all!
Thanks all!
No sweat. I doubt I'll get to it that soon but pretty sure I can fab something up when the time comes. Thanks though
One set of tire chains- Peerless 0232805 Auto-Trac Light Truck/SUV​
Bought new from Amazon January 2021. Only test fitted them and then put away. Never used. Only selling because I got bigger tires since I bought them. They were test fit on my K02 LT285/65/18 and fit perfect.
They're $115 on Amazon at the moment. So how about $75.
(posted on RS forum too)
I recently replaced mine. I did the old bump start to remove the nut. Worked well. If you need to borrow the socket and wrench let me know.
