The FJ coil design is prone to breaking at the area between the active, and dead coils, and really needs to be tapered wire to get the right result.
We spent lots of $ and lots of time, with many designs, to find that out.
We now have a coil we use with a 29" rear FJ shock that stays in there, with offset lower arms, to stop them contacting the housing.
The 80 rear, is a simple process for you to work out the details, I think.
Measure coil free height.
Measure distance between coil seats at full shock extension.
Cut the coils off and grind flat to within 10mm of your coil seat measurement when dropped with the shock.
Space the shock mount on the rear up 1" and that will give you more to trim the coil by, reduce your bump spacer an inch, same travel, just slightly different place.
Trim more than the distance beatween the coil seats, and fix the bottom of the coil to the housing seat, top will locate itself, if its only 10-20mm shorter than the seat distance.
Even if you dont like to do that, at least you will see/feel/try the set up, at the height, to see if it was worth it.
More than one way to skin a cat sometimes
