for those of you that have Line-X'd the flares...
When you reinstalled the flares did you use the rubber gasket between the flare & body?
Just pulled the flares last night (the ones that were still attached anyway. ) and I'll also need to do some repair (again) to the mounts on the inside of the flare. A couple of the mounting tabs have broken off. I had repaired them before using epoxy, but I was wondering if anyone had any suggestions for something stronger/better to use? ???
