Builds Fj73 Crawler build,
Built up a bit of cover for the fuel filler, Started off like this,
Finished like this, redid the recycled rear tube,
Still got good handful of mechanical bits to sort. Fuel injection, transfer gears or twin case, brake lines, 40's or 42's and finishing off the front axle. Amongst other things.
Built up a delete for the manual fuel pump, running the hi pressure pump direct with fuel injection planned,
Moved the rear axle back another 40mm,
New headlights,
Did a bit of cleaning up in the bay,deleted the heater feed and return, remounted the hydro assist reservoir, will be going with a Fitech kit soon,
Scored a OBP hydro handbrake,
Converted it to a vertical pull,
Snuck in around the screen , just,
Added an additional tube to give the screen edge a bit more coverage,
