Hi All and Happy New Year!
New to Mud again.
I have a 1990 FJ62 that while on the freeway doing about 65mph the transmission disengaged, essentially going into neutral. I pulled over and it wouldn't move in any gear including reverse. There is slight grinding going into park. I had been driving for about a half an hour.
The splines on the output shaft had stripped about a year or so ago, so I installed a mcnamara gear. Ran great until the freeway experience.
I plan on pulling the Trans oil pan off today. So first question is should I do a Rodney flush before or after I pull the trans oil pan out?
Second question: I pulled off the PTO cover plate and I can rotate the gear with my finger. Is this normal?
I was going to try all the easy things first before diving in to remove the transfer case. I am no expert, so my first instinct is that I screwed something up during the mcnamara install.
Any other suggestions for tests I should perform prior to digging in deeper.
Thank you.
Brad
New to Mud again.
Thank you.
Brad
