Oh wow, didn’t realize how long it’s been since I updated. Both a little and a lot have happened.
To start, it turns out the transfer case wasn’t really hot, I just thought it might be. Heat transfer from the transmission will do that. I didn’t figure that out until after I dumped a bunch of gear lube out onto the driveway trying to check the fluid level...I think I cleaned it up well and fast enough that my wife hasn’t noticed. Shhhh. No pictures of that!
Right about the date of the last posting my wife and I both started getting a cough. Then it got bad. We got tested and it took four days to find out we did *not* have covid-19, so that’s a plus, but two and a half weeks of coughing has sucked pretty bad. In the last five days it’s finally turned from a painful dry cough into something productive, so hopefully it clears up soon. The sickness has put a damper on my wrenching but not completely stopped things.
Did a valve adjustment; it is AMAZING how much that quieted the exhaust. There’s a bit of sludge under the valve cover but nothing like some of the engines I see resurrected on here:
Does anyone have a photo of a bored-out throttle body? The lighter color near the flapper almost looks like it was machined down after the rest; the throttle body is a continuous diameter from opening to manifold. Also, getting the valve cover off is so much easier without the air rail and heat shield that it’s not even funny.
Speaking of valve covers, anyone know what this number written on the back side of the cover means?
I had been planning to do the oil galley plug mod while the cover was off but, while I was driving around to warm the engine up, I noticed a coolant leak on the passenger side near the radiator drain plug. When we were turning the crank pulley to find TDC there was coolant coming off the fan blades. Decided to put the engine back together and troubleshoot the leak before diving into anything else. I spent a lot of time poking around with my borescope and cell phone trying to find the leak source; this was kind of a cool angle:
Long story short, it was the upper radiator hose. Easy fix, huzzah! Bought a new Toyota hose and clamps to replace the aftermarket POS that was installed. Pro tip: that hose has different diameters on each end. I put it on wrong the first time and it dumped a bunch of coolant so I had to do it over again. $49 including shipping but it’s pretty clearly a better hose and I think it will be reusable in my FJ40.
Spent some time trying to seal up the muffler because I am not paying for a nice exhaust on this rig. Unfortunately, this took an hour to tape and lasted, like, five minutes:
Today I changed out the distributor cap and rotor, that seems to have cleared up a lot of the vibration when the torque converter is locked up. It needed doing:
That seems to have smoothed out a bit of the vibration while the torque converter is locked up. There still is some, though, which makes me think the cylinders aren’t making power evenly. I figure either a couple cylinders have low compression or the injectors are unevenly gunked up. I got a new compression tester (old one bubbled the hose testing the 2F in my FJ40) so I’ll check that soon; I’ll send away the injectors for cleaning this winter. Maybe they’ll clear up a bit from being used; I think I’ve put more miles on it in a month than the previous owner had in several years.
