Did you glue down the carpet or just lay it down?Pics of final install. Seats to be cleaned next.
Just lay it down, seats , molding , etc will hold it in placeDid you glue down the carpet or just lay it down?
How much of each did you order? I’m about to do the same in my 60I just did this exact project a couple of weeks ago and used the 150mil over kilmat 80. I think you'll be happy with the end result. The cruiser is almost as quite as my 4th gen 4runner!
I think it was about 80 Squarefeet. 60 Sqaurefeet should be plenty if you're just doing the floors.How much of each did you order? I’m about to do the same in my 60
I just did this in my 60 and two boxes of 36 ft was enough for floor plus doors and back panels.How much of each did you order? I’m about to do the same in my 60
What floor mats are those?View attachment 2305059View attachment 2305060View attachment 2305061View attachment 2305063
All with conveniently cropped out rips in my driver's seat!
Ed, did you put the MLV facing the out side door skin or put it towards the inside of the cab? I’m about to this, glad I saw your post. Nice Work!!I kept the vapor barrier (well actually replaced the trashed stock material with new 6mm plastic) and added 1/8” thick Dynaliner to the back of the door cards. This coupled with Dynamat inside the door makes for an incredibly tight and quiet door.
You can see that I left it about 2” short of the door card edge so that the extra thickness doesn’t prevent the door clips from fully seating.
-Ed
thoughts on Stock Interior carpet?I did this recently with the stuff from stock interiors. Their video says to put it inside the doors though stuck to the outside panel, rather than inside the door cards. I had already removed the vapor barrier to undo the door latches, later replaced with new plastic.
I didn't cover the entire inner door but a pretty good amount in front, lesser amount in back. here's the driver door for an example..
What I like is how the door feels really solid now when you close it. Some from the insulation, probably more of it from the new door gasket, but either way just feels way more solid.
I stuck the rest of the sound dampening around kinda where I thought it could do the most good, could have used double the amount I ordered though but it was kinda expensive. I ordered their "SUV Cargo Area" kit and should have maybe got a bigger package. But in general, I'm fairly happy with how it turned out and the 60 does seem a bit quieter now with the added pad and new carpet.
In case anyone's looking for it, it's Bituthene lest you receive unexpected package contentsBitchathane
Pretty good my only gripe was there wasn't a new piece for the bottom of the rear seat... you can see more pics on my build thread, here: nakman's 60 build - https://risingsun4x4club.org/xf/threads/nakmans-60-build.30021/page-5#post-355285thoughts on Stock Interior carpet?
