kev60
TLCA Member:23722
Hi, I have a couple of questions for the FJ60 community. First question is some advice on wiring for my headlights. I replaced the stock switch for my headlights with another land-cruisers switch (after my turn signal would not work any more) that was a few years newer. Not everything lined up ( since the new cluster did not include the shaft for the headlights) and the shaft for the original switch was a different length but I eventually got it lined up so everything works. My problem is that my brights are always on since the shaft is always leaning forward for the brights. I can get the regular lights to go on but I have to hold the switch. The switch doesn't sit in the middle anymore and I am wondering if I am missing a spring or some part to hold the shaft there. If someone could just explain how the switch works for the brights than I may be able to figure out how to fix it. My other question was has any one found any after market fuel sender units for the FJ60, my fuel gauge always goes empty after about half and I have tried taking it out and cleaning it with no luck. I have only found one and its almost $200 which is more than I wish too spend on it. My last question is if anyone has put a small block chevy 350 with a NV4500 in a land-cruiser and if so how it handles, highway speed, and what transfer case they are running.
