Wanted FJ60 Manual (13 Viewers)
Lol. :flipoff2:
I had a lift for $200 lined up, but fell through today and had to make a decision, whether i wanted a lift before MLK wheeling or not.
Parts for 1978 FJ40 needed
I need the following items
-lock and key for my rear amby doors
-Side window glass for hardtop
-set of stock wheels with clips for disc brakes (Colorado)
-Brake Mastercylinder
-4 hubcaps front and rear
-Factory choke cable
-factory rearview mirror
you can still get hubcaps from the dealer, pretty reasonable, also I think new rims but they are a different color than grey
So, it took you 33 minutes from the time you posted your wanted ad till you decided to buy a new one?
Pretty much. :flipoff2:
40 minutes from getting a used lift for $200 to buying a new one
I found out my original deal fell through, so i posted the add. Then I realized there was no way I would get my stuff before MLK that way, or who knows when someone might have a set around. I then decided to call David and see what his price was on a new one, and before I hung up he had talked me into a new set. :D It'l do. :D
Funny that; It helps to have Kurt in the wings!
One thing I have learned is make the time zones work for you!
'75 Choke Cable
'75 Rear View Mirror
Where are you located?
AJ
65swb45 said:
How clean do you want it? Just useable, or restoration quality?
It doesn't need to be pretty. Cleanable would be nice, but it doesn't need to be perfect.
I still haven't gotten around to pulling mine off to try to weld it...
Ooops,
Guess the '75 Mirror won't fit the '78.
Sorry.
WELDING! :eek: You'll melt the whole wheel! You better shine a flashlight in there and make sure it's not just a plastic crack. I don't think a true metal crack is repairable.
rear door lock cylinder w/ 2 keys, new, $16 plus the ride.
PN 157-41
2 Taco parts wanted
Hola Y'all... a buddy just kissed a parking pole & needs a driver side mirror (the whole thing) a driver front fender flair/fender for his 2k Tacoma... anyone got a lead on these... used of course... le me know ASAP, gracias...-Ian
