Wanted FJ60 Manual (31 Viewers)
Early 40 Steering Wheel
Greetings people.
Looking for an early 1970-71 era FJ 40 Steering Wheel. The one I have is bent either from a large belly rubbing it or a violent collision resulting in a crushed rib cage:(
I dont need the center cap. would like the guts for the horn though.
Just need one not bent up. Not resto quality. Thanks.
Shipping to 43202. Columbus OH.
Would like one under $25 + the ride.
thanx - I made due and have used parts from my hardware store. If you don't need it and would be willing to send it my way for cost of shipping, that would be cool. Otherwise.. I apreciate it but I am set.
Thanks,
e.
Early Corrugated Hard Top?
Anyone out there have an inexpensive corrugated (pre 1967) hard top they want to get rid of? The soft top just doesn't cut it in Montana winters. Any condition acceptable. Thanks, Scott
Ambulance doors
Looking for a pair of rear ambulance doors for my 40.... No rust would be nice..
Zetasig,
I have a steering wheel from a 1971 FJ40. There is no horn guts. There are some cosmetic cracks in the plastic hub, but the spokes and rim are in good condition.
Contact me directly if you're still interested.
<FJ40Jim@aol.com>
Ph.740-862-2604
80 series rear locker diff
I want to buy a rear 3rd member 93-97 80 series w/ factory locker good or bad. I dont need the actuator either. I mainly need the carrier case which houses the spider gears and bolts to the ring gear.
Carl
the corrugated top won't be any warmer....it's single thin sheet of metal and the bifold doors let a lot of cold air through their non existant weatherstripping and poor sealing.
Bigger heater....
Look at a heavy equipment bone yard...find the heater core and fan assembly from a 72V Cat Motorgrader...swap the fans to 12V and YOU WILL HAVE HEAT! ;)
Good luck!
-Steve
i know it's not an early steering wheel, but i have a perfect condition wheel out of a 1980, everything is there and the horn and everything worked when i pulled it to put a 1981 style wheel on. if you would be interested e-mail me and i'll send you pics. super-phat-cat@shaw.ca
FJ45LV Left Rear Tail Light & door latches
I need a left rear tail light lenses, mine is all broken and taped. I also need the left side door closures for a 1967 4-door station wagon, FJ45LV. :confused:
Your best bet for the taillight lens will be either to call and order one from TLC4x4 or contact Foxfab on Pirate4x4.com. I would do a search on Pirate's website under the Landcruiser stuff. There is alot going on in the 45LV world over there.
What is the door closure part exactly you are looking for? Do you have pics? Heck post up some pics of your rig anyway. Love to see it. I have a '67 LV myself and always enjoy seeing others.
When you get a chance go into the 40 series section and send an email to orange45 with all of your info on the truck. As you may know there are only about 100 LV's in the US.
WTB FJ40 3.70 third member
I want to buy a complete FJ40 thrid member with a 3.70 ratio. I want something I can bolt in and run without rebuilding. PM me please.
Where in big sky are you? saying it might get real cold next week -30 to -40 around here
try mike fox aka foxfab for the lense, like marc said.
post a pic of your wagon, and send me the info for the registry! :D
HP 80 3rd member
Looking for a FJ80 HP 3rd.
Would rather it be non-elocker since I have an ARB lined up.
Gearing doesn't matter, since I'll be going 488s anyways.
The closer to NJ or NY the better...
exhaust manifold
I need an exhaust manifold for an f engine. I need one that has the 4 ractangular holes as picture below.
