Wanted FJ60 Manual (25 Viewers)
I have a booster I removed from my March '73 FJ40 for a disc brake conversion. Worked great before removal and has been boxed in the garage since (approx. 1 year). Master is still attached (although a bit leaked on with brake fluid while in the box). I can send you a pic if you want. $40 plus shipping. Let me know if you're interested.
Dom
DomSmith said:
DAMN!! Was that "Shaw Is. Wash" there the whole time? My eyes must be bad!!
No it was not, your eyes are fine...
Alcan springs
I have a set of 4-6" Alcan springs for sale. They are new, I fitted them up to my FJ40 once to determine shock length then swaped them out until shocks arived. I never got around to installing the brand 4 new Warn Black Diamond XT's. When tested on a RTI ramp they stuffed a 35" Baja Terrain up in the front fender without touching the inner lip of the fender. The backs are a little stiff for the spares I carried, but if you don't lug around that many tools and spares, you could remove a leaf. I would like $800 for the package. I'm in VA. cruise1977@aol.com
Josh
I have a set of hub caps for sale. $10 ea. rear view mirror $10 I think I have a choke cable $5 and which glass do you need? The big side window, corner or push out vent?
cruise1977@aol.com
Josh
Like I said, I haven't taken it off to get a good look. The plastic around one of the spokes is cracked (and has been for many many years) near the hub. I finally broke the whole spoke free from the hub.
I was thinking about trimming the plastic back a bit so it wouldn't melt much. If it doesn't work... well, that's why I'm asking around for a replacement. :D And if it's ugly, maybe the PS conversion will move up on the list.
sorry didn't mean to play triks on your eyes. Hay that sounds like a good price to me. would you like a money order. Let me me know what you'd like. A pic would be good thanks. Brad
Need 97 FZJ80 Valve Cover
I'm in need of a valve cover that will fit my 1997 FZJ80.
emailed you
T/C Vacuum Switch Valve Needed
I need a transfercase vacuum switching valve for an FJ62. These are located on the firewall to the left of the engine (looking from the front). There are a pair of them, I need the bottom one that pulls the TC out of 4WD. Either might work but I'm not sure.
TIA
Sorry for the delay in getting back to you all. I picked these up locally and quick shipped them to a friend. Thanks for all the feedback.
My guess is that you will need to do similar mods as needed for spring over. some kind of z link or high steer. I knoticed some bump steer driving it to the rti ramp. You will also need to do some rear drive shaft mods. Rotate pumpkin up or cv joint shaft.
Josh
did you get this? if not I have a whole set of grey armrests from an 85 fj60 I parted
850J springs
Looking for a set of used or new 850J springs. Anyone have some for sale?
e-mail me @ acbarta@yahoo.com
Thanks
