Wanted FJ60 Manual (1 Viewer)
Search E bay parts for Toyota wheel spacers, lots of them starting at $75 pair
Butch
only a few bucks from your local vautozone or checker or whatever.
Ummmm....
For which one?
Poser, unless you can get back to me on email(bdowns05@yahoo.com) sometime tonight, i will probably be hitting up 4x4connection tomorrow monring to just buy some new ones. let me know if you can help me out though. Thanks.
Dealer has the good ones!
3_puppies said:
Where are you located? looks like a CA plate
DOH, Sorry everyone. I am located in Southern Oregon. I actually bought this cruiser about 1.5 weeks ago. I am working on restoring/tricking it out : )
for some reason I want steel.. just easy to work with.. No spider cracks ..
subzali said:
Does anybody have the resistor for the low/high setting on the heater blower kicking around? A piece of mine is broke off...
I do. Condition unknown. Yours for $5, shipped priority mail (included).
Just dug them out...
and need to figure what year they came off of! I will probably have pics by monday. Sorry for the delay...
why won't this work? aside from modifying the front bearing retainer to fit the larger toyota throw out bearing , buying the longer pilot bearing, retapping the two lower bolt holes on the bellhousing and bolting together I don't see any problem ! people say the bolt pattern on the 3b and the f and 2f are the same !
This is from a toyota diesel site....
3B Diesel engines were availavble with 4 and 5 speed transmissions. They share the same bolt pattern as F, 2F, & 3F gas engine but require a special input shaft that is a different length and spline count as F or H series gas & diesel engines. A H55F from a 3B Engine will not work in a F or H series engine without getting this new input shaft. It is also NOT the same shaft that is found in H or F series transmissions, you must buy this part from Toyota.
Engel 45 fridge
If anybody's got a line on an Engel 45, let me know.
Thanks.
sent you a PM
Piggy Parts Needed
Hi all, I need a few parts to complete 1978 55 project. Driver side taillight lens cover, ash tray for door behind driver side , and ,as we all need , weatherstrip for rear window. Thanks, Mike
Triple pulley, OS for a/c or not? I have both styles. :)
I've got the last brand new NOS speedo needle. Not sure why any more! :o
