FJ60 Driver's Window won't stay tightly closed.
Billings, Montana
Just wondering if anyone out there has had the same problem. I've had my 60 for over 25 years, and it just started backing off enough to make it whistle when driving. Any quick hacks out there for this problem? Thanks.
Start with your rubber window run. Is is cracked or mis aligned in the channel? Old rubber seals start to fade after 20+ years.
Classic symptom of a worn out regulator.
You could pull the door panel and see if the regulator needs to be adjusted.. there are a few bolts in the interior facing side of the door panel that hold the regulator in place. You may be able to loosen and adjust the regulator positioning so that is closes right. Otherwise sounds like the regulator may be bad
