SOLD FJ40 Throttle Linkage
TN
  1. 40 Series
Looking for throttle linkage for my ‘74 FJ40. I have the pedal for linkage and am thinking about using a city racer carb, but I’m lacking everything in between.
Thanks!
I have this, missing a rod.
That looks like the second iteration Kevin. 2F. The first iteration in ‘74 would have different standoff points because the F engine carb plenum is closer to the head. Almost an inch closer.
Not saying it won’t work. Might work with some tinkering. And I’m sure your ‘garage’ price is much better than my ‘shop overhead’ price.
I may have the early version...will check later
When I installed a 2f with a 77 or so manifold in my 74 I didn’t realize that the 74 setup was slightly different until I was hooking up carb linkage that was the original for the 74. I was trying to figure out what the hell was going on and then remembered reading here on Mud about the 2f manifolds sit about an inch further from the block.
Here is the other one I spoke of.
Bottom one in picture.
Thanks for all in help everyone. I didn’t realize my F.5 linkage was different then the later.
If anyone has everything together for a 74 let me know. I’m needing the vertical rod that connects from the pedal up to the horizontal rod, the horizontal rod, the small rod at the end and the carb end bracket. Only parts I don’t need are the petal and firewall bracket where the vertical and horizontal links come together.
Thanks!
Just to update this thread I’ve found everything I needed. Thanks everyone.
hi ....
perhaps there a few important key items parts topics you may have over looked on your 1974 set up you now have ..?
- your fire wall bracket it metal , every single other part on it related to it is a weal and tear age and time part most of all the 3 different black grommet bushings
- the period correct return spring
- the gas pedal boot , on fire wall , 1 ' DINE " size hole , you will have dead smell mice terds in your nice 74 for life , nesting in a blower motor fan , that u the pull the fan pull , is instant Walking Dead mouse guts everywhere in July , that is a bad thing .....
don't forget to steep your new Nylon infused rotational bearing , fire wall grommet at full boil , in your T-TEN beaker , no less then 6 solid mintes /...
:wrench::wrench::wrench:
Bumping my old thread almost a year later to the day, but I’m finally installing the linkage I purchased a year ago and ran into a problem.
The vertical rod that goes from the pedal up the firewall to the horizontal link I have is ~5.5 inches long adjusted all the way out and I’m needing one ~7 inches long (preferably with a little adjustment either way). Anyone have one laying around?
Also looking for a throttle return spring.
