FJ40 that green thing
1996 KZJ78 Prado
Good day, got a stock power steering pump setup on the 82 FJ40 with 2F engine. Replaced the pump with rebuilt unit from Napa (moved the reservoir over), had the steering gearbox rebuilt by a pro and new hoses all recently installed, did the recommended bleed cycle to get the air out of the lines, double checked fluid levels at idle and with engine off and then took it for a short drive. Power steering worked good but did make a low pitched whine, figured that was normal.
Got back from the drive, 60-65 mph for 10 minutes and come back to a mess of power steering fluid under the hood. seems to be coming out of a small valve under the pully shaft on the front of they pump body, looks to be some kind of pressure relief valve there according to parts diagrams. What could cause this to be spewing fluid even at idle and not turning the wheels and does anyone have ideas how to trouble shoot or fix the issue? I feel like I've eliminated all weak spots by replacing every part of the system with new or rebuilt.
Thanks!
Thanks!
