1972 FJ40 -- F Engine
Heard a "whistle" at idle and when decelerating. Figured it was the intake/exhaust manifold gasket - took it apart... it was shot. Then, separated the intake/exhaust - that was a bugger of a job... have a new gasket for here too. I then sandblasted the exhaust manifold. Cleaned up real nice but the thermo rod is still frozen - at about half mast - I guess I can live with that.
Found a crack 1.5" long (hairline but through-and-through)-- can it be fixed? Heard you can not successfullly weld cast. A friend said to try to grind a groove and fill with JB Weld and grind it down. The crack starts at a corner beneath the intake manifold and migrates towards the #3 cylinder.
Is this a hopeless salvage attempt? It only has a minor warpage "up" towards the #6 cylinder.
If so, does anybody have a used stock exhaust manifold laying around that they replaced with a header -- my intake is in good shape and I want to try to maintain the stock appearance on the FJ40 "F" engine plus I have a newer exhaust system.
