[quote author=godzilla link=board=1;threadid=8291;start=msg70322#msg70322 date=1070406311]
Landpimp, where did you get the mega fuse and military spec terminals at? Sweet setup. Thanks for the response.
[/quote]
Mega Fuse at West Marine(but Wragler has them as well) Mega fuse holder(comes with the 2 red caps) $18, fuses are $8(I got a spare as well) you can get the fuses in many different amp rating.
I got the Mil Spec terminals from Wranger for $6ish each but after I ordered I found another source that was half the price
see
http://www.pirate4x4.com/forum/showthread.php?s=&threadid=192067&highlight=mil+spec
Even the local auto parts store can get them for $5 each.
As far as I can tell Wrangler is the only source for the Mil spec terminal covers, they are well worth it however as I looked FOREVER for a cover that would work on my fj80 dual bat set up.
Cable was 1/0 welding cable, 50ft for $37 I think. cable ends......I finaly found nice ones(tinned copper, closed end) for $1 each at a local screw shop, West Marine was $1.80.....and you use ALOT of cable ends.
I got the crimper from Napa for $30 and it's OK but not great, check out the one that McMaster has...I have used that one before and it's nicer IMOP, either way it;s a handy tool to have.
Odyssey batts were from
http://www.batteryweb.com/odyssey.cfm
best price by far, great service as well, cheap shiping. I love the brass studs on them, normal size but also allow a 3/8 bolt on the top, also you cant brake the stud off....nice feature for the gorilla mechanic
Orbitals Extremes are $109ish(comparable to a yellow top, with some added benifts). I will not buy an Optima again, I still have 2 red tops in service and one yellow top when they die(and they will) I will go Orbital or Odyssey.
Tray mod was 2 peices of angle iron
I had to move nothing at all. SUPER SUPER happy with how it came out.
I'm adding a Mean Green to the 82 fj40 very soon.
any question feel free to ask
John H
