- Thread starter
- #41
If you had a picture of the inside, looking up into that corner, that would be great. It's above the fuse box (of course) and to the right and above the wire harness run up in the corner. I think the hole starts at the horizontal surface where water should drain from the vents and continues down the sidewall and a little of the firewall. So, it's a bastard to get into. Guess I'll have to pull all of that dashboard stuff, including the wire harness, to get a welder in there. I wonder if it could be done from the interior and not have to pull the fender? That's why more info is good. Thanks![/QUO
this may not help, but i do have a donor cruiser in my yard with most of the interior out of it, i will get you a better pic tomorrow,it will be around lunch time as i come home for lunch from work
