Someone with fabrication facilities should buy that, reverse engineer it, then build and sell a bunch of them to 'mudders, then actually deliver them.![]()
What's there to really reverse engineer? Wit's end just pieced a kit together more or less.
I read another post recently where the evap canister was relocated down on the frame. I like the idea but how will it fair in the long term being subjected to water crossings and such?20k miles after refresh and running like a champion.At 220k miles now and another 5k oil change in the books. I will never get tired of how easy it is to replace the oil filter or work on other stuff with the evap canister relocated.
Mine’s almost 8 years old and can still run my ARB fridge for two days and still start the carDisappointingly, the Odyssey battery is failing to hold up overnight with the fridge running and it is just shy of 4 years old. Fingers crossed I get a free replacement.
I does worry me now because of its age
I like the way you secure the battery cables.
It’s a struggle for me to get that group 31 battery in there 79 lbs.
Get kettle bells and work out! No excuses!Mine’s almost 8 years old and can still run my ARB fridge for two days and still start the car
I like the idea but I don’t think these canisters are designed to be submerged. Not really sure…Have not completed, but will in short order, run a hose from the vent port up high. Having said that, it is up pretty high.
Good going… I bought an X2 group 31 in 2021. That’s batteries and bulbs brand. American made, used to be North Star.Odyssey is sending me a new battery. I am very glad to have made the 4 year cutoff and that they stood by the claim.
Did you ever check the voltage with your fridge running? I'm switching back to non-AGM for the SAS trip as I installed the Eco Flow Alternator charger without replacing the alternator. Perhaps when I spend money on my Alternator then I'll be able to spend money on an Odyssey.
The 80W alternator is not keeping up and the charger is bringing my voltage down and AGM batteries don't charge at low voltages as the Flooded Battery.
So... any alternator recommendations that pair nicely?
wow... 150A?! part number? is it a drop in or did you need to customize a bracket?
