Builds Fix'n up the Land Cruiser.....
Blue Sea 300A distribution fuse block. 150A for the alternator, 100A for rear cargo power and one extra stud. Made the new cables for the alternator and battery, then finished terminating the rear power cable. Box attached with ss allen bolts and locknuts.
Valve cover SHOULD be here tomorrow......🤞
Has it been a while? Where did you order from? That engine bay is looking superb.
Waiting for the shop to get to it, as they have been backed up. Received a pic early this AM.
What the driver fender looks like now that everything is wrapped up.
Did you have to mod the battery box to fit that group 31? I’m picking up my X2 power 31m Friday.
Fits like a glove. I did make my own hold down when I went to 31.
Valve cover on, new plugs, new valve cover bolts and oil cap seal.
Dizzy on, new rotor, o-ring, upper coolant hoses...
Wrapped the rest of the main harness and installed heater valve with rear heater bypass hose.
If sex was a valve cover….wow Paul, your VC is the envy of nK and the PRC🤣 seriously, looks rad
I'd did wine and dine it 1st.
New brake hardware, front pads and lines front and rear.
Last peice for the cooling system was this heater hose. I also added some caps to the rear heater pipes to clean it up.
