This site may earn a commission from merchant affiliate links, including eBay, Amazon, Skimlinks, and others.
Does this fix shakey mirror sindrom? if so where did you buy it?
Yes, from @Outsane
Wow the old yellow one!
They must have been sitting on a bench for awhile!
Installed 2019.
97 40th ~ Paul
What man can teach another to understand this truth? What angel can teach it to an angel? What angel can teach it to a man? We must ask it of you, seek it in you; we must knock at your door. Only then shall we receive what we ask and find what we seek; only then will the door be opened to us.
Let love be genuine; hate what is evil, hold fast to what is good; love one another with brotherly affection; outdo one another in showing honor.
Blue Sea 300A distribution fuse block. 150A for the alternator, 100A for rear cargo power and one extra stud. Made the new cables for the alternator and battery, then finished terminating the rear power cable. Box attached with ss allen bolts and locknuts.
97 40th ~ Paul
Valve cover SHOULD be here tomorrow......
97 40th ~ Paul
Has it been a while? Where did you order from? That engine bay is looking superb.
1994 FZJ80, 3x, Emerald Green, TLCA #27610
1994 FZJ-80 Let the Adventure Ensue
1997 FZJ80, 3x, 2AB, Stock
1997 FZJ80, 40th Anniversary, stock and in need of love
1993 FZJ80, 3x locked, relatively stock
Waiting for the shop to get to it, as they have been backed up. Received a pic early this AM.
97 40th ~ Paul
Oh yeah, I forgot you already had it and was getting it glammed up. Looking good Paul.
What the driver fender looks like now that everything is wrapped up.
97 40th ~ Paul
Battle Ground, WA
GOLD Star
Did you have to mod the battery box to fit that group 31? I’m picking up my X2 power 31m Friday.
1996 FZJ80- Awaiting transformation
1993 FZJ80- "The Champ” RIP
1994 FZJ80- A victim of poor judgement
2005 Dodge CTD with some stuff.....
Fits like a glove. I did make my own hold down when I went to 31.
97 40th ~ Paul
Valve cover on, new plugs, new valve cover bolts and oil cap seal.
Dizzy on, new rotor, o-ring, upper coolant hoses...
Wrapped the rest of the main harness and installed heater valve with rear heater bypass hose.
97 40th ~ Paul
If sex was a valve cover….wow Paul, your VC is the envy of nK and the PRC
seriously, looks rad
I'd did wine and dine it 1st.
97 40th ~ Paul
New brake hardware, front pads and lines front and rear.
97 40th ~ Paul
Last peice for the cooling system was this heater hose. I also added some caps to the rear heater pipes to clean it up.
97 40th ~ Paul
She runs! Coolant in, trans filled and cycled and ran to operating temperature. Found one leak at a brake line fitting by the master cylinder and snugged it up. No other leaks thus far.
I popped a MIL at the end of my idle run for a misfire on #3. Screw driver to the ear and injector is firing. Pulled the plug and I have spark so re-seated plug and wires. That is as far as I had time to get into it. In a couple weeks I will have the downpipe welded and then run some compression checks if needed.
Priming oil:
97 40th ~ Paul
