Here are some pictures of our first camping trip in our SOA'd 84 FJ 60.
Loaded down with mud from the road to Colbran
New camera does cool stuff
Gravel pit camping. Also about the limit of my wife's wheeling threshold(so far), She says she's ready for Moab.
I will break down some of the details this weekend.
Over the winter, mostly this spring, I spent some time under the 60 get'n it done.
Front Axle:
Pulled out, disassembled, and cleaned.
Housing sent to Poffitt's for cut and turn and related welding
Hubs/Knuckles rebuilt with bearing and seal kits from Man-a-fre
'95 4-runner calipers from NAPA
Brembo replacement rotors, Man-a-Fre
Marlin hy-steer kit
Sky Manufacturing shock mounts
Rancho RS5000
Braided stainless brake lines
New custom bent(by me) hard lines
Spring packs disassembled cleaned and painted
Stock length greasable shackles and pins
Poly bushings
Flat black paint on what needed it
Not done to front (yet):
Rebuild, re-gear and lock diff
Extend front drive shaft
Add-a-Leafs
Bump stops
Rear Axle:
Sringpacks cleaned and painted
I will disassemble them when I add add-a-leafs
Perches welded on with correct pinion angle
Old perches cut off
Sky Manu. shock tabs
Rancho RS5000
New, stock length greasable shackles and pins
Poly bushings
Cleaned and painted
Extended stainless brake line
Not done to rear:
Rebuild, re-gear, lock diff
Rebuild brakes or disc conversion
Bump stops
Rebuilt stock brake Master
Front Axle:
Marlin hy-steer kit
Rancho RS5000
Poly bushings
Add-a-Leafs
Bump stops
Rear Axle:
Old perches cut off
Rancho RS5000
Poly bushings
Cleaned and painted
Not done to rear:
Bump stops
