- Thread starter
- #41
Lame!
The Landcruiser is a SUV and not a TRUCK.
The reason why the issue came back is because you had this attitude about how much you paid for the car and they responed by shutting you up and quickly greasing the problem. VERY likely a part will need to be changed or adjusted which takes time and patience. Your arrogance is why caused your Landcruiser to develop this problem once again, although even just slighly.
Show the service guy some respect and he will get your job done correctly. Otherwise, they will just grease you drivetrain again which will mask the issue which which will just bring you back.
Unfortunetly, your very likely stuck with issue for life and stuck with the quick grease and lube which the dealer will know masks the problem...and to that.....because even though you paid $70k for your Toyota which actually is not the most expensive Toyota truck in history....you got played like a fool by the service guy and to that "I smile and chuckle" because in all honestly, you are no different than a guy who drive a Tercel or Tacoma because after all you drive a Toyota...just like them. .
Wow...such nice statements on your 12th post! I appriciate your opinion, but I think you need to learn what sarcasm is. If you read my conversation again with the service person, you may see the sarcasm in my tone when speaking to him (which he laughed at also)....or maybe that is something you cannot recognize.
I am not going to debate with you if I gave any respect to the person I was talking to, because you were not there, I was. He mentioned how long things would take etc, and he never got an argument from me. I waited patiently until they called my name.
BTW to someone who had an acura before...the LC is a truck. If you don't like the way I describe my LC....well I am really upset a about that.
BTW...have a nice day!
While I don't necessarily share the animosity displayed above, I do agree that greasing just masks the problem. Especially in a full-time 4WD vehicle, there are lots of parts all moving against one another all the time (crank to transmission to t-case to two driveshafts to two diffs full of gears to four axles shafts to four hubs, etc.). They all wear eventually and a little wear gets compounded since there are so many components in the system. That said, this is just a trait of full-time systems (especially heavy-duty systems like in a Cruiser) and is more annoying than actually a mechanical problem. However, in a new $70K vehicle, it is unacceptable. If it does turn out to be the typical driveline slop, then the only way to truly eliminate it is to replace parts.
From reading the other posts in the 100 area etc. I do know that if the grease didn't fix the issue, that something would need to be replaced, looked at more, etc.
Despite what the jerky, sorry I mean user, above mentioned...there are some things I expect not to happen with my $70 TRUCK and one is not to have a clunk in the drivetrain.
It is good to know (from you and reading other posts) that it is more of a annoying issue then an actual mechanical failure issue.
