Coolerman
- Joined
- Jan 5, 2004
- Threads
- 143
- Messages
- 6,766
- Location
- Paint Lick, KY
- Website
- www.globalsoftware-inc.com
Which model of Red Arc gizmo do you have? Hard to tell if it is the cause of your issue without knowing exactly what it does.
Ignoring the Red Arc device, since the internal regulator in the alternator is the only other thing that controls the voltage level in the truck, it has to be the source of the too high voltage. Since it only happens after a couple of hours driving, heat is probably causing a failure in the regulator.
Since the later FJ40's have the independent turn bulbs, we here in the USA have to use an electrical gizmo that converts the three light system to a two light system that our trailers use. Do your trailers have this same issue or do they have separate turn signals also? If the trailers are like ours, and you have the gizmo installed, it may have an issue.
Best I can do without more info...
