First drive
Hi All
I'm slowly winning the battle of the alternator.
After taking in all the advice from dedicated Mudders this is what I have done since the last post.
First changing the alternator to 120 amp sounded good at first but I have to stop thinking Old School.
Why do I need to charge the Camper batteries with the Toyota? I have a bank of solar cells mounted on the camper roof doing that job.
So with the camper now not in the equation all I need is a dual battery system.
Many years ago I had a dual battery system in my 1974 Forty Series . This system worked fine with 2 led acid batteries and a mechanical off / on switch.
So what has changed?
I removed the AGM battery and replaced it with a lead acid .
My voltage to the battery is now 13.5 volt up 1 volt on the AGM battery at 2000 rpm .Why ?
Next I removed the OEM voltage reg and replaced it with the Era after market voltage reg .
At idle I am now getting 13.5 volt and 14.8 volt at 2000 RPM.
I took the forty for a spin and the 14.8 volt was stable.
I now invested $500.00 in a Redarc DC to DC in vehicle charger . ( will Nat ever get her new kitchen? )
Using Anderson plugs I hook up the Redarc
to the start battery and then to the AGM battery.
I needed to see a customer at the Gold Coast 80 ks away so I took the Forty for a run ,the result being the AGM is now fully charged.
I now need to mount the AGM . Under the hood is full so that means I have to mount the aux battery in the cabin.
In travels I found a Thunder Box.
This battery pack is now fully moveable and I will fit only when required.
Tomorrow I will make the set up look pretty.
The removable battery pack lends it self for use in both the Forty Series and my Nissan.
Some more photos.
Cheers Peter
...via IH8MUD app
