Bull Cruiser can fix that shine for you...
https://forum.ih8mud.com/100-series-cruisers/343524-random-100-tech-talk-thread-2.html#post5176760
If you end up doin' your fogs and highs.... this is what i meant for placement. red circles
I installed the ballast inside/behind the corner lamp.
I'll be buying another 2 sets.
Sent from my iPhone
Let's s see a pic of the pattern on a wall. And thanks for the Tapatalk info.
They only lit when the low beams were on..they shut off when the highs were engaged due to the original factory design of the fog-lamps..
Well here`s what I did to get around this little "problem"....
I removed both halves` of the "clamshell" surrounding the steering column..
One gold phillips scew (aimed at an angle towards the driver underneath the steering wheel)..and then I turned the wheel left and right to reveal two more black phillips screws ( also facing the driver)..Then I "pulled" apart at the halves, separating them... NOTE: It might be easier to do this by first removing the dash panel (below the guages and behind the column)
Then I located the connector that plugs into Comb-switch, it is referred to as " C-16" in the Factory Toyota EWD, and is the 17 pin white plug on the left side of the steering wheel facing UP..
I then REMOVED pin #17 from the harness connector with a very small flat head screwdriver by carefully prying up on the pin retainer...wire/pin #17 is a Red/light Blue wire and is in the VERY BOTTOM RIGHT of the connector as you are looking AT THE CONNECTION SIDE AND PINS, WITH THE RELEASE TAB ON TOP ... You will also notice that this Red/lightBlue wire just simply "loops" right back into the connector as pin #10
Then I simply cut off the pin on the end of the wire, and ran it to a good ground.
BTW..The wire is JUST long enough (after you cut the pin off) to crimp on a small eyelet and attach it to the metal tab that hangs down from the column that the GOLD phillips screw (you removed earlier) screws into..
Now my new Hella lights work just like I wanted them to..With the factory wiring, the factory relay AND with
the factory switch... on both low AND high beams !!
HOW FRIGGIN` EASY WAS THAT ?!
Fine. Now I HAVE to get those HID's. How does the quality look Shane? Are they waterproof?
Bull Cruiser, I prefer the 4000k color temps.... 8000k is not sexy at all. Screams "Pull me over!"
