weekly update
We had a sister come up from Medford to attend a training class last week. Upon shuffling the vehicles around to park the cruiser behind the others (I leave for work first) I bumped into the fire heidrant that is located on the corner of our lot.
It was dark and I got a little too friendly
with it and I heard large
PSSSSH sound. I looked to that corner and saw no water (thank goodness) but noticed the front right drop several inches. I got out and saw the damage and drove the cruiser up the driveway first so I could park it (I'd be taking the car to work instead). I put a jack under the axle to get the rim off the ground and here is the damage to the tire. I don't think a few tire slugs were going to fix that.
That's a pretty good sidewall rip, enough to get my arm in.
The
suggested we just get another cheap 35 and stick it on. I told her I might as well throw on the 38s instead of waste money on a 35. She said she didn't understand why I wanted to put such a big tire on since hopping into the truck in a dress for church doesn't excite her. I think I'm losing her
. So what do I do? Just like any loving husband I'll just build her a step because the 38s are goin' on! To get all the tires to the shop to swap them over I needed to tow the trailer so I put on the old original tires. If anyone still wonders if it will look alright doing a SOA and running small tires please look at the following pic.
I went to a local little tire joint and helped them mount the 38s. They were the max for their machine. It was interesting to see how they did it and it looks like reseating a bead on the trail might be challenging. For balance I used 14 oz. of heavy weight airsoft pellets in each tire. I followed the chart on
Tire Chart Map and added another oz. or two to be safe. I had a few onlookers ask me some questions and what I was going to run them on. I did end up popping the hood and showing some of the conversion but once the tires were done I drove home and I parked the 60 for a test fitting.
This pic is more for a comparison
Here's the meat.
I jacked up one side and put them on. Now we're talkin'!
Yup, now we're talking clearance. Remember, I've moved the rear axle reward and the front axle forward a couple inches. This is the rear clearance with the quarter panel.
I've got 4 fingers between the tire and the body mount. I'll have to stuff it to see what I need to cut out.
Here's a look at the front.
I'll definitely be hitting on the front when stuffing. Some of that will need to come out.
I did some full turn tests and actually don't hit anything standing still. Add some road bumps or trail roots in the mix and I'll be getting contact.
That's almost full turn to the left. I'll probably need to take a couple of inches off that too since with a SR the axle will move back.
Front spring clearance almost full turn to the left. I should be fine. Full turns usually only happen at slower speeds, at least for me, don't know about some of you crazies out there.
I threw on the other front tire to get a shot of the front.
