Factory roof rack removal (2 Viewers)
pictures are in no particular order. i was able to take the rails off with a torx t40. i thought it was a t35 for a second, but it was a t40. was really very easy. hardest part was lifting off the covers to get to the bolts. my bolts were not rusted or nasty at all.
i bought new bolts from ace hardware and got a metal washer and fiber washer on there, and used some blue rtv. called toyota, the rectangular access covers are not sold separately from the gutter trim assembly. you have to buy the whole thing at like $110 each. until i figure something besides dropping $220 for four access covers, blue painters tape will do! going to get my roof painted white within the month to address blistering clear coat and to subtly trick it out.
Thanks everyone for their advice!
Do any of you who removed your rack have still have it handy?
Specifically, the 3 legged, long version roof rack that mounted at the most forward mount (A), abeam the sunroof and the two rear most mounts (C&D)
I currently have the stock ‘07 LX rack that only has two legs and mounts to the second (B) and fourth (D) mounting points but am in need of longer rack.
Fellas-
The rubbery-plastic-ish bottom foot on the roof racks... is it the same on the LX to the LC? Also, anyone have the Toy PN's for this? I need the 4 corners if it's the same and in black.
Painted my LX feet and they look great in terms of color but in general the parts are old and decrepit.
Did you find the part number for these?
I thought I would throw mine into the mix. My middle section was slightly different than what I had seen posted, and was just a normal bolt instead of Torx. The middle was not attached via a keyhole of sorts, it simply had a plastic cover that I popped off and revealed the one bolt:
The small channel that is left exposed, I remember reading that it is not necessary to do anything with that exposure as it is not a point of leaking. The passenger side molding is not seated as well as the driver's side, would this be any cause for concern? It's not flapping in the wind, but near the top it does protrude a bit more than the driver's side:
@Pskhaat Have you tried putting a tap through the hole? Ive had a couple bolts like that where Ive needed to get the tap in there to get the threads realigned. Also, place some silicone on the treads just for good measure. Good Luck
Posting here because this seems like the best thread...a little confused by all the different variations.
I have an 03 LX with the shorter rack...would like to swap in a longer version off a LC to bring the front load bar forward, making a more stable mount for my RTT. Can't justify an aftermarket rack right now with all of the other things that need doing.
In theory, I should be able to just cut the gutter, opening the space for the front most bolts, and pop on a longer 3 point oem rack? Is this correct?
Just wanted to add a little to this old thread. I recently removed my own rack and it went relatively smooth due to the info here. One thing I did differently was to slide the cover strip forward to remove it. The first step was to pick up on the back until the clip either unclips or breaks free from the roof. Then, while I was sliding it forward, I’d release the retaining clips as they became visible in the open slots. Here are some pictures of the clips so you know what you’re dealing with.
Adding a little more rather than starting a new thread. Not liking the gutter gap and not wanting to spend $25 on plastic cover strips, I decided to make my own strips. I cut some strips from .032” aluminum, roughly 1” by 17”, covered them in shrink wrap, slid them in place and adhered them with some sealant. Overall, I think they came out pretty good.
