- Joined
- Sep 4, 2020
- Threads
- 138
- Messages
- 2,054
- Location
- Brunei Darussalam
- Website
- eurasiaoverland.com
- Thread starter
- #21
I'm no automotive electrician, and not sure it's relevant to this discussion, but remember the Toyotas are negatively switched. From memory there is always power on both high and low beam at the back of the light and the factory relay switches the ground.
Thanks, I had heard of that but was not clear on what it meant. As a (rather poor) physicist of sorts, it's second nature to me that electrons flow from negative to positive so I cannot get my head around the electrical engineer's idea that current flows from positive to negative and that a 'negatively switched' circuit has the switch downstream of (for example) the lamp. Anyhow, thanks for the tip!
Back to the relay question; in my BJ60 at least, unless there is a relay in the headlight switch on the steering column (which I am pretty sure is just a regular switch), there is only one relay for the headlights, so at least one circuit is switched by the switch.
Therefore, the answer is: it is definitely better to use a dedicated aftermarket light harness... and that is what I am going to do.
In a parallel thread I am looking at adding a relay-swtiched rear fog light to my car, using the unused push-button 4WD actuation circuit. This is another example of a strange use of a relay where only one of the VSVs is switched by a relay, and the other by a switch. Still seems odd to me.
