- Thread starter
- #281
I decided to focus on the lift mechanism because that is the one thing that stands in my way of actually being able to use the trailer. So after consulting W/ MRPEPPER (mechanical engineer) on my lift design I began building the legs. I just have the one leg fabbed so far. Im still not finalized on the hinge. The springs and cables are not yet inside, but the pullys are. The pully axles are flush with the outside of the tubes so that the cables will be centered in the tube and not come in contact with the tube walls. The tubes are 1 1/4" OD which allows 1 1/16 th" ID for the 1" OD trampoline springs to hide inside. I also chose round tubes as oposed to square since they are a smoother surface and may come in contact with me in the night.
With the legs installed the top will sit aprox. 35" above the tub with an additional 10" or so of head room inside. - Plenty of room to sit up in, but not much more. I really didnt want to make it much taller. The bed area is only meant for sleeping in & changing clothes. The trailer already sits tall with 33" tires and I have to be able to reach the cap from the ground to lift it. Plus, once the tent material is installed I didn't want to create any more of a wind sail than I had to. It can get pretty windy in the desert. Looks like final maximum hieght will be around 7'-6". Perfect hieght for mounting a hanibal awning (or my home built version)
I took a few pics to show the hinge progression.
just need to build 3 more and install the mounting hardware and the top should raise straight up hopefully with some significant mechanical assistance from the springs.
.I took a few pics to show the hinge progression.
