Voodoogirl said:How far does this stick out compared to the stock bumper? What about thickness? Stock bumper, top to bottom, vs. exe-one. Looks good, but seems a little bigger than I thought.
Kathie
jfonz said:Edit: Don't worry Kath... Once you've got 35's and 3.5" of lift everything will look perfect![]()
Voodoogirl said:Shhhhh, they're only 34's![]()
mapleton cruiser said:kathy how are you getting 3.5" of lift? and are you really getting 35,s
Hey Kathie,Voodoogirl said:Just 34's. Already got 'em on my stock wheels sitting in the garage. I have cut the front body mounts and am already running 33's, so I shouldn't need 3.5". The lift I'm getting will be right around ~3" in the front.
Kathie
bigbill25 said:Hey Kathie,
What brand/model tires are these? I haven't had any luck finding 34's... Thanks
--Bill
Tire Diameter Width Speedo Error
265/70R17 31.60" 10.43" 0%
285/70R17 32.70" 11.22" 3.490% slow
295/70R17 33.25" 11.61" 5.227% slow
jfonz said:good news! We found a solution that allows the bumper & winch to fit without having to move the AC line! I'll post some internal structure pics as soon as the adjustments have been made....
DanKunz said:I installed the allpro bumper on my sister's FJ and it was not that hard to bend the AC line. It is very very long and quite a bit out from the rad so I was able to brace the junctions and bend it gently with my fingers. No issues that I know of in Atlanta heat, so it must have worked fine!
Plus, if you want to keep the front face of a bumper closer to the truck, bending this line is a good idea, otherwise you will add inches to accomodate a winch just to prevent bending something that can easily be bent.
Ok its wednesday.mapleton cruiser said:james told me the first one should be done wed. or thurs.
otjustin said:Will the Expedition One front bumpers be compatible with the stock front skid plate? Lovin the designs and excited about the possible rock rails/sliders.
