- Joined
- Sep 6, 2002
- Threads
- 243
- Messages
- 3,587
I'm NOT disputing the FSM..... it says grind or replace..... all I want to know is, "is the crank nitrided from the factory"....
Ah sorry, misunderstood. I don't know the answer…
cheers,
J
If the FSM says "grind", then it isn't nitrided.
A simple test with a file can show you. Nitrided surfaces are so hard a file will skate across the top.
"Respect" is all I can say.
Your title had me skipping over this thread all these weeks, thinking it was a bad vacuum tube or that you had fiddeled with something like timing or fuel and cocked it up. When it went on for more than a page, I had to have a peep and I am very impressed. Good luck, it looks as if you have it all in hand and you are asking the right question to the right people. Don't you just love this forum???
G
This makes sense to me, but the only one I can think of who might be willing to test this out would be surfponto with his extra crank just laying around. I'm just too damn fond of mine.![]()
This brought up a question I've been pondering but have been unable to resolve. The rebuild kit from EA comes with bags of gaskets and bags of copper/brass/aluminum washers with no directions or identification. Some of these I know, but most I'm a little at a loss to define. The two top right sets of 6 I know belong to the injectors, and I think the smaller 6 crush washers in the middle of the image also go with the injectors, but the rest I'm at a loss for. The one on the far right middle I had assumed was for the oil pump since the I.D. was the same, even if the O.D. or thickness wasn't.
A lot of the copper seals are for different applications. Looking at your set you have 1hdt injector seals there, seals for the factory turbo oil return on Hdt(ft)(fte) and others. So i assume the copper seals are a baggie for many applications.
You also have diff and transmission seals (aluminum) and the blue oil pan seal. So no worries if you don't use all of them.
Yes, use the port for the boost sensor.
Seem like eons since I did my HD.... From memory I used all the washers and o-rings in the EA kit. 1 will be for your IP pump timing, 4 brass for vane pump connect, etc. edit: the 12 small copper lower-center are for the HD injector fuel rail, as Jan said and I think 2 brass might be for the HD turbo union bolt.
Last post for the morning before I go torque the head and see if I can get nearly everything off the shelves!
The all important oil orifice. What does this do exactly?
Old vs. new. Where does this sensor go if it doesn't fit in the new water outlet?
Some misc items from the EA kit, but what are they for??
Getting everything ready for the head install, these seem okay and they check out within spec with plastigauge, they just don't look perfect like I prefer. How often do these get replaced?
When I pulled the cam out of the packaging from the machine shop, I found quite a bit of surface rust. I used some 000 steel wool with WD-40 to take it off with as minimal work as I could get away with. It came off fairly easily and looks good now, but not sure if that's cause for more than annoyance. How common is this? It's a reputable shop so this was surprising to me.
The oil orifice limits oil flow and by that increases pressure.
There are 2 water outlets, one with and one without sensor hole (obviously). What is wrong with the old one?
Forgot what the plastic thingies are for from the kit.
The cam caps look perfectly fine. They are matched to the head, so you cannot just replace them without buying a new head. For peace of mind you could have them checked by your shop, or did they do that? Do you have a new bearing for #1?
I never liked the fact that the caps are the bearings. On the FT and FTE you actually have bearings in there....
The cam is fine. They should have coated it with oil, but with the 000 you are good.
Great work!!
plastic "things" are boots you put over the con rod bolts when installing the pistons into the block to prevent scuffing of the crank.
put them on the bolts, slide piston in hole with bolts over the crank
remove boots and move on to the next one.
I've been following this thread https://forum.ih8mud.com/threads/gturbo-install-dan-from-okinawas-experience.794952/ and it's rather fortunate I had with the few things that have cropped up regarding this turbo install. While it may be a great turbo in the end, there are a few things which don't quite jive yet. This is one of them. The fix for now is to grind off the tube on the inside and that allows the holes to line up.
What did I do today? Installed a Mother F'ing turbo. Made my weekend.
And just so the issues that caused this rebuild to happen never happens again, a pre-turbo EGT.
Pending the arrival of my turbo stay from Japan 4x4, it was looking like I was going to get to put the engine back in the truck this weekend, until I noticed this. You can probably tell it's a little wonky from this angle.
And a little closer. WTF. Fortunately these are universal for all 80's so I'll probably be able to get one off a parts rig locally instead of $109 from Toyota or ordering from Canada, but still. Now I have to track one down. How does this even happen?!
On a side note, this is yet another piece that needs to go on in proper order, i.e. - before the turbo. Oh well.
