when you remove the head there is usually a whee bit of coolant still in the passages. this can move as you lift the head and get into the oil passages
not a big deal, i would not worry.
plus, with a full rebuild, life is going to be good.
the #5 was on its way out. you picked a good time to rebuild.
hint, once you have it back together, resist the urge to go to extended oil changes as recommended by some on the forum. your oil is your life blood of the engine ...
and, you can keep an eye on the internals better with 5000 km oil changes. a good idea is every few oil changes send a sample off for testing.
it is better to have cheap oil with a good filter than contaminated expensive oil in the engine for a longer time.
remember, it is YOUR money that is rebuilding the engine, not theirs.
a good machine shop will pop the frost plugs before tank cleansing and install new after, same with the small oil journal plugs. just, before you start reassembling, make sure ALL the plugs are back in, the last engine i had rebuilt the shop missed the 2 small threaded oil plugs in the back.
it is daunting but once you are done, if you have taken your time and followed the book to the letter, then you will have a great feeling of accomplishment when it is purring away in the truck again.
This was something that was curious to me, can you see the "bubbles"? I think it's coolant, but I found a few drops of semi-clear/white liquid coming off the bottom of the block once I'd separated it and pulled the crank. I have no idea on this one.
The worst offender on the lower crank bearings was #5, probably not terrible by catastrophic standards but pretty significantly scored. Those are all fingernail thickness.
