- Thread starter
- #41
So I'm trying to get to the bottom of something with all of the various ways of driving and tuning these rigs for high passes. Since I have no pyrometer, I have no reading of EGT's, therefore I turned the fuel down. Now when I go up hills, I have much less smoke, but since I have the low powered 1HZ AND I can't hold 2nd manually, I have to either drive it in 3rd @ 1600-2200 rpm or drop way down to 1st @ 3000 rpm, depending on the length of the hill. In 1st there's no smoke and sometimes in 3rd there's no smoke, but at that low rpm under load up very long mountain passes, things are surely heating up. So, regarding the engine, which is best, considering my instruments to monitor the internals of the engine is practically nil? What about using the low range for the really big sections where the grade is over 10%?
The other half of this question is the tranny. I've mostly been dropping to 1st to go up passes since I thought that keeping rpm's up also keeps the tranny temps down. However, I had a quick 1500 ft climb yesterday that, when we arrived at the top, I could smell something odd. I stopped and checked it out and it was definitely coming from the bottom rear half of the car. It didn't smell burnt, but it did smell kind of sweet and like something was hot. I thought I'd check the tranny fluid and it was definitely low, as in, showing the low end of cold while idling, but its still correctly colored and doesn't smell bad directly. So, in 3000 miles I've lost a good amount of ATF but there are no leaks or drips around the tranny. Could it burn off due to the way I've been driving it? In other words, what I'm really trying to get at is, what's the best way to drive these steep passes given everything else about my car?
What I wouldn't give for an H150 right about now... What's the going rate on those things anyway?
