I stopped by the machine shop today finally after a few months of letting the cruiser sit out front as a persistent reminder of a job left unfinished. I had brought the rod caps and rod bearings with me since that's as far as I've dug into this thus far. I was pretty amazed at how he was able to reason through what could have happened with a close inspection of the bearings. One of his theories was that the pump was out of time and hammering on the pistons and consequently the bearings eventually caused one of them to fail, making all the others lose pressure. I kind of agree that this is a fair possibility since I'll admit that the secondary timing of the pump was something I assumed to be a tune up procedure and not detrimental. Why would I think that?? Good question.
Leit
Good to see the project up and running,even if its a 2nd attempt.
I guess the machine shop guys reasoning is sound regarding the pump timing being out ,but I would have thought the engine would take a bit more punishment than that and it would have been running so rough it would have alerted you.
The pump wasnt new so it must have been in service on the engine before it was rebuilt. Was anything changed on the pump before it went back on?
If nothing was changed ,then it would have been hammering the engine before as well?
I also agree with some others that bad timing isn't the cause of this.... something basic and major is out of wack or has somehow moved to be out... maybe they'll find it... maybe not.
Having messed with the pump timing more than I would like to have, it's pretty obvious when it's not in the right range. Advanced timing to that extent would not be ignorable. It would be tough to start, stumble, clatter like crazy, rattle, shake, it might go good, but not from a stop and not at low RPM.
Keep a close eye on everything, I don't think it was the pump timing.
Any end to this saga?
I've thought of this thread from time to time as well, hoping Leit's doing alright and is getting ready to take another run at this thing!
I concur. No way this was pump timing. For some reason you did not get oil to that bearing, or the bearing was the wrong size, or something major like that. It clearly got very hot.
What is the plan anyway? New crank? Regrind the crank? How bout the groove in that journal?
Good luck,
J
