Exahust pipe diamter
Discussion in 'Diesel Tech / 24 volts' started by Tapage, Aug 5, 2005.
  1. Tapage
    Tapage Club 4X4 Panamá SILVER Star
    23,345
    1,370
    Apr 4, 2003
    Panamá
    Hi all folks .. that is teh question very easy ..
    in my 2H I have the stock 2" diameter from exhaust manifol all the way, wih glass pack.
    What do you have in yours Diesel engines .?
  2. crushers
    crushers post ho
    22,189
    206
    Feb 10, 2004
    Tara Ontario
    2 1/2" aluminized with free flowing muffler...
  3. Deny
    Deny
    3,919
    207
    Jan 18, 2005
    Fort St John, BC
    2 1/2 with a baffle pack, exiting infront of the passenger rear tire. It was quite a noticable difference going from 2 to 2 1/2.
    Cheers,
    Deny
  4. Tapage
    23,345
    1,370
    Apr 4, 2003
    Panamá
    Did you thing I need to go to 2 1/2 " in my " stock " 2H .. ?
    Is the answer is yes .. from exhaust manifold without muffler . :D
  5. Deny
    Deny
    3,919
    207
    Jan 18, 2005
    Fort St John, BC
    I think it will help a bit, but it is no Turbo! No muffler, will be TOO loud, without a turbo. A glass pack on a 2 1/2 exhast is pretty loud, too loud for me, but my brother had the long 2 foot glasspack with 2 1/2 exhast on his BJ60, and it was not too bad (took it off because it now rubs his new 35s)
    Cheers,
    Deny
  6. Tapage
    23,345
    1,370
    Apr 4, 2003
    Panamá
    I'm pretty sure that 2 1/2" exaust is not a turbo .. and I know maybe this setup without turbo or muffler comes to loud ..
    But .. sometimes is funny .. ! :D
  7. crushers
    crushers post ho
    22,189
    206
    Feb 10, 2004
    Tara Ontario
    i recommend a 2 1/2 for even the NA 3B...
  8. Technikev
    Technikev
    269
    2
    Jun 14, 2005
    Edmonton, AB
    Made a difference in power, I'm assuming. What engine is that on? Do you have a pyro and if so what difference in EGT?
    Wayne: Who do you use for an exhaust shop?
    -Kevin
  9. crushers
    crushers post ho
    22,189
    206
    Feb 10, 2004
    Tara Ontario
    i have a shop down here that has been doing my exhaust for 15 years. they know exactly what i want and where. they are expensive to be sure but they do phenomenal work...
    minute muffler...
  10. Deny
    Deny
    3,919
    207
    Jan 18, 2005
    Fort St John, BC
  11. colin 4
    colin 4
    91
    May 1, 2005
    CANADA
    I need more top end power for towing. If I'm going to go through the trouble of replacing my exhaust I want to do it right. 2H, h55f, 31's(planning for 33's) Should I go 2 1/2 all the way from the manifold?
    New muffler? What is a free flow muffler? And for pipe diameter, how big is to big on a 2h - need back pressure right?
  12. colin 4
    colin 4
    91
    May 1, 2005
    CANADA
    how necessary is a pyro and why? Forgive my ignorance.....
  13. bigbrowndog
    bigbrowndog
    1,662
    17
    Apr 30, 2005
    N.Q. australia
    Safari T3 and 3inch mandrel exhaust with 3inch muffler:bounce: :bounce: . I was told by Qld Transport that a muffler must be fitted otherwise the vehicle did not comply with its relevant A.D.R. Rule:crybaby: and therefore they deemed it as "not roadworthy".:ban: :beer:
  14. jzilla
    jzilla
    1,713
    55
    Feb 26, 2003
    Vancouver, BC, Canada
    have a 3 inch straight through, i figured why not
  15. brownbear
    brownbear Mod in Hibernation Moderator
    6,842
    157
    Sep 6, 2004
    North West Ontario
    2H guys should go to 3" IMOP.....why skimp.??
    I'm doing exhuast next month on my 3B with a turbo, I am going 3" with an almuminzed muffler. Exiting infront of the LH back wheel.
    Right where my dog jumps in :D
  16. cruiser_guy
    cruiser_guy
    11,197
    36
    Jan 20, 2003
    Wherever the truck stops!!
    I have 2 1/2" pipe that follows the stock routing to help deaden noise and NO MUFFLER. I figured a muffler simply redirects the exhaust flow several times within the muffler thus deadening sound with the accompanying back pressure. I'd rather redirect the flow gently in the pipe with less back pressure. The less back pressure you have the better power you'll have. Of course the back pressure from the turbo gives added power since it's performing useful work in spinning the compressor.
  17. colin 4
    colin 4
    91
    May 1, 2005
    CANADA
    But you have a turbo. If I go 3" will my engine be running rough because I don't have enough back pressure? There must be some sort of science with this stuff isn't there? Surely you diesel heads out there have some sort of max tailpipe diameter equation for a non-turbo 2H? Okay so maybe not.....I'll go as big as I can but my dream is to get a million km out of my truck so I don't want to cause extra wear and tear y'know? Thanks for your patience. ;p
  18. Mickldo
    Mickldo
    1,047
    17
    Feb 18, 2006
    Maryborough, QLD, Aust.
    Don't be suckered in to running too big. I'm running a 3" mandrel bend on my turboed 1HZ but after talking to a mate who owns a dyno tune perfomance shop and owns a turboed intercooled 100 series. He runs a 2 3/4" exhaust and has run a 3" on his as well. He told me he got more power with the 2 3/4" system. This discussion was a while ago now so I don't remember the hp #. Also can't remember if he was running mufflers or not.
    Don't know about a normally aspirated 2H but if a turboed intercooled 4.2L doesn't need a 3", maybe you can save some $ and go for a slightly smaller pipe.
  19. cruiser_guy
    cruiser_guy
    11,197
    36
    Jan 20, 2003
    There comes a time where larger pipe doesn't make economic sense. The back pressure however, from everything I've read, is a myth! Less back pressure is good. The only problem is it's also louder if not properly dealt with.
  20. crushers
    crushers post ho
    22,189
    206
    Feb 10, 2004
    Tara Ontario
    yes, pipe size does not make a huge difference to performance. we are not increasing the size of the pipe for this reason, we are doing this to reduce the EGTs stuck in the pipe.
    on the dyno, test rig was a cummins (size and year was forgotten by me long ago) there was a test done here in town, 3",4",6" exhaust and the HP and torque readings stayed the same.
    i recommend the 2 1/2" exhaust size on all the units from the 2LT up to the 1HZ turbo'd. this system has served me good for years, no burnt valves and little restriction to the system.
    if you want to go bigger, good for you. i tried the 3" on the 2LT, it seemed to help the EGTs but an extremely tight fit and a very expensive bill.
    cheers
