On my 72 FJ40, There is what I assume to be a charcol canister on the inside of my front fender, it is attached to a device by hard lines which has long been disconnected that at one time appears it would have had vacume lines running to it. Also from the canister are hard lines going to another canister in the center section of my bench seat which is in turn connected to my fuel tank.
Question is, other than needing to cap any ports on my fuel tank, do I need to do anything special when I remove all of this? Is it neccesary for controling fumes in the cab if I put a hard top on the truck? And lastly, would it really make a difference environmentally if hooked it all back up? I am smog exempt so I don't have to have it, and the canister is probably no longer functional.
Also there is a small rectangular device on the inside of the passenger side fender just above the battery with three electrical terminals on it. The electrical system on this rig has been "replaced" by a PO, and I am not sure what this is. I would guess that it may have been like a main bus or something before. It hasn't been connected in a long time, just don't know if it is something I should hold on to. I'll likely toss it, unless one of you guys needs it.
