Euro-spec headlights
The lights apprear much brighter than they really are (I'm not good with cameras:doh: )
I'm hoping that I would be able to snap similar pics with the Euro lights installed, just to see what kind of difference it would make (or not).
Anyway... I know nobody asked me to do this. I just had nothing better to do. :rolleyes: :D
Cool write up and pics mot.:cheers:
My 90 model OZ HZJ80 came standard with the little square sealed beams. A Zippo Lighter would put out more light. I went to the local wrecking yard and bought 4 Nissan Urvan headlights for $15ea. I fitted them with some Narva Plus 50 bulbs. The outers were H4 12V60/55W and the inners H1(?) 12V100W. Huge improvement over stock. I know the small rectangular lights don't have the best lenses or reflectors but I prefer them to the larger lights as I do a lot of dirt road driving and would rather replace one small cheap light than one big expensive light if one was hit by a rock. Plus I think they have a smaller target area than the bigger lights.
Thanks, Mick!
OK, I wasn't going to put in the Euro lights if nobody posted after I did yesterday. But since Mick posted I've decided to do it, just for him. ;p :D
So it was pretty straight forward to replace the JDM lights, except some of the screw tabs and stuff for the grill didn't match up, as well as needing to put the screw-holding part of/for the corner markers into the Euro lights.
Since this was just a temporal thing I didn't bother with swapping the headlight squirters, either. Neither did I install the leveling harness.
Enough with the foreplay....
Pic 1: Had to break down and buy a pair of H1 bulbs for the highbeams.
I had to stand in front of all the light displays and had to torture myself trying to decide between the 4400 Kelvin ones or the 3900 ones. I had, however, decided already to go with CATZ (Don't ask me why, but their packaging, their HP, and their 1 yr warranty always sat well with me;) ) I went with the 3900 Kelvin bulbs since it was whiter (less blue) and thought it would match the H4's I already had.
Pic 2: Close up
Pic 3 JDM light
Pic 4: Backside of JDM
Pic 5: Backside of Euro
Pic 6: H1 slot
Pic 7: Rubber cover removed
Pic 8: What the rest of the bulb looks like
Pic 9: Tight squeeze
Pic 10: Bulb in and clip on
Pic: 11: The socket thingy going on
Pic: 12: Looking good so far
Pic 13: Same H4
Pic 14: Different angle (55/60w)
Pic 15: It's in there
Pic 16: Both bulbs in
Pic 17: Euro up close
Pic 20: Darkness
Pic 21: Lows (Notice the light pattern's rise to the right)
Pic 22: Highs
Pic 23: Gate open
Pic 24: Low beams
Pic 25: High beams
Pic 26: I forgot to take the "before" pic tonight. So this one is from last night
Pic 27: Lows
Pic 28: Highs
I usually wear contact lenses, but today I had my glasses on, which made it a little difficult for drawing a fair comparison/conclusion.
Although the lows seemed fairly similar in illumination/performance the highs seemed a fair bit brighter/further/wider with the Euro lights.
To tell you the truth, I ran down to a near-by department store to get some pastries tonight and it was lighting it up (with high beams) the road and the surrounding area better than the JDM set-up. But again, maybe I "wanted" it to be better.
I was going to put the JDM lights back on/in tomorrow, but will wait another day and see the lights without my glasses (with contacts).
Anyway, just an FYI and FWIW.
Mot
P.S. I'll post the direct comparison pics:
Pic 29: JDM low
Pic 30: Euro low
Pic 31: JDM highs
Pic 32: Euro highs (Maybe I should have raised them a little higher, but the Euro lights appear to have a little more "Ooomph", maybe)
Pic 33: JDM low
Pic 34: Euro low
JDM lows look better, at least to me, here. The Euro H4 housing has a metal cover/shade inside that supposedly reflects the light back to the reflector which the JDM lights do not have, which robs the Euro lights of some lumens.:confused: :confused: :confused: ) Again, I could/should have aimed the Euro lights a little higher to make it a fairer comparison.
Pic 35: JDM highs
Pic 36: Euro highs (I'll definitely have to aim them higher as you can see the difference between them where the JDM's are hitting the guardrail dead-on, the Euro's are lighting the ground, about half-way down the gravel road.)
Pic 39: JDM high's
Pic 40: Euro high's
My wife is asking me if all this is necessary, especially at 1:35 in the morning.:crybaby:
I'm gonna hit the hay! ;p
Good night!
Mot :flipoff2:
Great pics Mot!
Thanks,
-B-
