My fridge has twice this weekend gone bye bye. It start d beeping and stopped cooling. Hit the reset both times and got it to work, but twice it just died like that.
You can check for a fuse in the plug connector where it plugs into the cigarette lighter adapter. You can also test voltage with a voltmeter in the fridge end of both the 12 volt plug and 120 volt brick. Make sure the polarity is the same on both the 120 volt and 12 volt connectors. When you repaired the ligther plug, what broke and how did you repair it?
Other than that, there may be a fuse between the power socket on the cooler and the control board. I wouldnt know how to get to that to look, but those are starting points.
Shouldn't have a problem.So will a environ cooler kill the battery in the cruiser if left running for about 2.5 days while at expo east? Bringing my boys and one of them takes meds that have to stay cold.
Unfortunately not. these sold out super quick. Maybe find someone selling one.Are these still available?
Yes. It whines a bit. I run mine in the teardrop until we get the awning out, then relocate it out under the awning. I keep some heavy stuff on the lid to keep smaller nosy critters from getting into it.Digging up this thread up!
Used my cooler for the first time this weekend camping and it worked great. We had it packed FULL. Had to buy an AC/DC converter with cigarette plug since my truck doesn’t have anything but AC 3 prong plugs. For reference, this is the one I bought - https://www.amazon.com/dp/B07JGS8CN2?tag=ihco-20
Question: is it common for these coolers to make a high pitch whine / sound while running? It’s not that noticeable in the bed of my pickup while camping but inside the house it’s noticeable. Filter is clean and it cools as expected.
