Thread title says it all, but here are the details re-posted from a clubhouse thread. The incident happened on a long, steep incline on I-5 north of Los Angeles called "The Grapevine". It's a notorious car killer. The A/C was off and it was 65-70F outside. I was driving around 55-65 mph in 3rd with O/D off, so 3-3.5K rpm or so for a prolonged time under load.
The truck will be fixed. I just haven't figured out what all it needs and how I'm going to fix it. I've got to diagnose the overheating first. I know the bottom end will need work, and of course a head gasket, but I wouldn't do that without figuring out what caused the temp to spike first so it won't happen again. I'm a 1-2 banana mechanic at best; mostly fluid changes and brakes. I've done a few alternators, a power steering pump and some suspension work in the past but nothing on the 80.
The truck came with a plastic radiator installed when I got it last August. PO said he'd done the thermostat and radiator as PM a year ago along with dizzy o-ring, plugs and wires and intake hose. Seemed like normal '80 stuff to me so it didn't set off any alarms at the time of purchase. The truck has been driven much harder, in hotter temps, in the past without any temp variation on the factory gauge. (I know the factory gauge wasn't telling me much, point being I had no prior indications of a problem).
First thing on my to do list, after clearing out some space in the garage, is to drain the fluids pull the plugs and look around. Should I bother with Blackstone labs knowing that my engine needs work? I'd like to do a leakdown test on it, should I do that before I drain the fluids? Is that a tool I can rent?
I'm thinking of trying to remove and re-install the engine myself. This is far beyond the scope of my abilities, but there's only one way to learn and I have the best resources in the world on this forum. Could I deliver a complete long block to a machine shop and receive back the same, or do I need to disassemble/reassemble?
Should I cut my losses and go lease a Prius? Naaaaaaaaah. But I'm gonna need a lot of help.
I'd already drained my oil by the time the spark plug test was recommended. I've even done that on another car previously, so I should have thought of that myself. I haven't cut open the filter yet either. My grinder took a dump last summer and I don't really want to do it with a Drimmel. I'll get to that eventually, but my Blackstone kit arrived yesterday so I'll do both. I've pretty much stripped the passenger side and front of the engine clean. I haven't tackled the driver side yet, saving that fun for last.As previously suggested, cut the oil filter open. The plugs look good to me too. I'm thinking it is in the lower end somewhere with that sparkly debris you found earlier. Did I miss it, or did you do the "pull one plug wire off at a time" test to see if the knock went away at idle?
Search on here, you will find that it’s much easier and faster to pull both together. Please don’t make the same mistake I did.
You can not. CAN NOT get a wobbly up to the top back bolts on the bellhousing
