Glad we are able to help. Keep that FSM close and reference it as much as possible. It’s extremely thorough.
My results have been mixed with the FSM. I know it's going to be essential during reassembly for the torque values, but I can't find anything in there to save myself. It's like a huge library with no card catalog or Dewey decimal; everything is in there but good luck finding it. The search on here is instant and I'm moving on to the next job rather than scrolling through thousands of pages. I'd better get comfortable with it though, because I won't be getting this lump put back together without it.Glad we are able to help. Keep that FSM close and reference it as much as possible. It’s extremely thorough.
Yeah don't do this. Sure it's easier to cut holes in your floor but that's a crap way to do things.The trick to getting the top bellhousing bolts is to peel back the carpet and drill 1/4 inch holes in the firewall until the light from a flashlight shines on the bolt head. Then drill a 1.5 inch hole with a hole saw drill and you can put a socket on it.
Once you have it back in, put a 1.5 inch Dorman plug over the hole and plug any left over 1/4 inch holes with silicone caulk.
Get a 3 ft extension with an impact wobble socket and lower the transfer case crossmember down some. It's not that hard.
Or just pull the engine, trans and transfer case together like I did.
EDIT: Nevermind, that was stupidly easy. Excuse me while I go delete my internet existence hahaha.
I'm sorry, I figured it out, and it was a dumb question. It was the end of the cable, where you lock it into the throttle body.
So if your disconnecting the trans kick down that sounds like you're pulling just the engine? If you pull both you don't have to remove that.
You can just disconnect the ecu by the glove box and feed the wires through the firewall and not disconnect every sensor on the engine and transmission. If you pull just the engine you need to disconnect the transmission harness connectors.
You will have to remove the shifter if you pull the trans.
Be very mindful of the heater valve on the firewall. They break easy and are like 80 bucks
I'd remove the coolant pipe on the driver side too because it sticks out far.
Ahh yes.. the "while I'm in there" ... You start out with a 500 dollar project total and end up with the house refinanced, kids college fund depleted and a really nice 80 series.I'll be pulling everything out together, but eventually I'll need it stripped down to the block, so if I did an extra step now it shouldn't really matter in the long run. Like removing the alternator bracket. I'll be pulling the upper radiator hose, and probably the water pump too, while it's still in the truck. I'll try the harness through the firewall trick, but it still has to come off so that's really about me not wanting to do the intake yet. I'm trying to do as much as I can before calling in help, then I'd like to get it to a machinist ASAP before it spends too long sitting in my garage gathering dust.
Oh, and the heater control valve has started turning brown, so I'm afraid it's going on the list too. At this rate I'll be lucky if I can reuse wiper blades when I'm done.
