Put a new transmission in the LC over the weekend. Got in to start it up last night and test my work and on the first turn of the key the ENG fuse blew. Checked all my electrical connections to the trans and tc and they are all pluged in and it does not appear that you can plug the wrong ones together [due to shape].
After checking all my connections I tried again and "pop" goes the fuse. I'm at a loss I did not mess with anything other than the trans and tc. just seeing if anyone has had an issue of this nature or any good ideas on where to start.
There is a ground strap on the back of the tc [where the rear drive shaft meets] that goes up to the floor. I may not have put this back in the correct place on the tc. if anyone can shoot me a photo that would be great so i can rule that out.
As best I could i looked down along the firewall and dont see anyting pincehed on broken.
on a side note: this had not been an issued before, but while under the vehicle i noticed there are on 02 sensors they are not in the pipe and they have been unpluged from the harness. how worried sould I be about them miss.
Thanks for your help.
