this thread had a bypass done by a member on the HCV and said it works fine.
Bypass Heater control valve?
How about oven cleaner?
/thanks/.
air filter canister is the big one in the middle?
also, i priced the heater control valve. retail is like $70. but i couldn’t find the diagram for the part so i can’t tell what other hoses i need. it’s not under HVAC > heater. maybe i should check in the FSM and see if i can at least see a diagram?
any way i can ask you what picture i need to take to see if the PHH was done? i am kind of assuming the heater control valve will be a piece of cake if the PHH was done but i am “wrench bootstrapping” myself from a motorcycle here so i’m trying to allocate my skills properly...
THANK YOU
jon
hey RM.View attachment 1835435
Follow the circled piped to the other end, and you've located the PHH.
Looking at the rest of that Heater hose mess, my guess is no, its never been changed.
Why were all those hoses blocked/cut, You might want to check the rear heater hoses/pipes before you address the top side.
You can find the rear pipes and hoses under the heat shields between the catalytic converters and the passenger floor.
Happy hunting!
Oh and don't let Simple Green or Purple Power sit on aluminum, its corrosive to that metal.
Make sure you get it all rinsed off.
Simple Green makes an Aircraft grade that is much more gentle on Al.
As for what I would feel safe about spraying with a pressure washer under the hood:
ABSOLUTELY NOTHING! That's just begging for a disaster.
thank you.......yes
